How To Reset "Service Required" Light? - Mitsubishi Forum - Mitsubishi Enthusiast Forums
LinkBack Thread Tools Search this Thread
Old 03-26-2008, 02:30 AM
Default How To Reset "Service Required" Light?
I have a 1989 Mitsubishi Montero LS Sport with 6 cylinder 3.0 liter engine that just passed 200,000 miles....the "Service Required" Light has come on. How do you reset the "Service Required" light??? I have serviced the transmission, transfer box, and the complete 3.0 liter engine as fully as possible. I cannot locate the switch in the dashboard to "throw" to reset the "Service Required" light for the next 200,000 miles. I understand that this switch is somewhere behind the dashbord. Does anyone know precisely WHERE this "reset switch" is located? How do you reach it? In the meantime the "Service Required" light stays on continually! Thank you so much. Scooter[/align]
Old 03-26-2008, 09:21 AM
dsm1990gsx's Avatar
Default RE: How To Reset "Service Required" Light?
That might mean you have a problem w/ the car, see if there are any codes and to reset it just dissconect the battery for 5-10 min and it should go out.
Old 03-26-2008, 03:45 PM
More like 30 seconds - 1 min
Old 03-26-2008, 07:13 PM
that switch is behind the dash. someone just called us yesterday asking where it was
Old 03-27-2008, 01:10 PM
dsm1990gsx's Avatar
Quote:
ORIGINAL: Sebba
Yeah your right I was thinking abt the newer cars that have (KAM) keep alive memory.
Old 03-31-2008, 10:16 PM
hello! the switch your asking about is on the back side of the instrument cluster. you dont have to completely remove it to get access to the switch.pop off the top trim piece and look on the left side of the cluster, its just a little black toggle switch, very small. just simply use a pair of angle pliers or something small that is curved on the end to stick in there and simply move it up or down. depending on what postion its in, simply move it to the opposite postion. you cant use a scanner to clear that light. battery disconnect wont work either. have to move that toggle switch!! good luck!! greg....
Thread Thread Starter Forum Replies Last Post
"Service Required" but no error codes.....huh? clattin Mitsubishi Outlander 4 06-27-2013 07:14 AM
"Service Required" indicator on dash board GPSeek Mitsubishi Outlander 9 11-07-2012 03:13 PM
Key service required on dash Shanehane Mitsubishi Outlander 10 09-03-2012 03:06 PM
service required sign vrxprince Off Topic 0 12-10-2011 02:49 AM
My 1989 Montero passed 200,000 miles! How do I reset "Service Required" light? scooter Everything else 1 03-26-2008 03:41 PM
Tags
03, 1989, 1990, eclipse, galant, light, maintenance, manual, mitsubishi, montero, owners, required, reset, service, switch
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
