timing
timing
2000 gallant. Broke timing belt. I replaced it & car will not ttart. Took it off turned engine 180, still no start. It sounds as if it had no spark. Checked plugs/coils OK.. Any thoughts?
uhhh....
Tdc #1.
Line up your cams.
Belt on.
Check compression.
If you broke it while running, id expect a fair bit of damage.
If it has a dizzy, and no spark, id expect you sheared the drive pinion key.
Tdc #1.
Line up your cams.
Belt on.
Check compression.
All pulleys on mark, yes
Sounds like no compression, lady said it always sounded that way.
Broke while d, yes. I'll check drive pinion key-compression. Thanx
Ooh, yes there is spark, dizzy?
