Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
advice on adding larger fuel injector
Old 03-22-2015, 09:46 PM
djsp's Avatar
Question advice on adding larger fuel injector
I was told that the factory computer will not recognize larger fuel injectors. So what do I need to do in order to over ride this system.
My car is a 2003 eclipse with a factory blue printed 3.0 with a Ripped modification super charger as well as a Vortec V -5G cold air intake. I installed the WB 255 fuel pump as well as added a fuel filter. The last thing I need is fuel injectors. the local performance shop said they were factory 220 and I needed at least 550 or even 750s. So how do I cure this problem?
please and thank you
Old 03-23-2015, 02:49 AM
Akzle's Avatar
ecu reflash.
Old 05-13-2015, 09:06 PM
up-and-down's Avatar
Akzle is correct you will need to reflash your ecu and adding a piggyback would surely be useful.
Kaiser Sosa
12-04-2023 05:34 AM
dfwoods
04-08-2013 01:31 PM
dfwoods
04-08-2013 01:26 PM
ybnormal70
05-15-2005 03:12 PM
Quick Reply: advice on adding larger fuel injector
