Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
speed meter need help
Old 09-16-2008, 10:37 PM
eclipsekilla's Avatar
Default speed meter need help
have anyone .....do a swap transmission for a 420a before, auto to manual .....??
Old 09-16-2008, 10:51 PM
Default RE: speed meter need help
Yes, its fairly easy.
Old 09-16-2008, 10:55 PM
yea i know ....is easy
but the funny thing is my speed meter doesnt work ...
because i can't find the wires harness to connect to the manual trans
help needed ......
Old 09-16-2008, 11:33 PM
You need to find out whether your setup uses mechanical speedo or electronic one. Most of the modern cars use electronic type, which is a little attachment (called sender) that has a gear mechanically connecting inside the gearbox and two/three wires going out to the speedo in the instrument cluster. Check for any hanging free connectors under your car around the gearbox.
It could be a broken sender too.
Old 09-16-2008, 11:45 PM
well my 420a it use electronic .......so i will just check for the hanging wire .....thanks
Rock Crater
12-12-2008 02:39 PM
Khaz
07-23-2008 01:40 AM
BlackMurcielago
12-10-2006 01:24 AM
fwerp
04-13-2006 05:11 PM
16psi eclipse
09-19-2005 07:01 PM
Quick Reply: speed meter need help
