manual window door panel removal? - Mitsubishi Forum - Mitsubishi Enthusiast Forums
Old 08-06-2006, 01:05 AM
Default manual window door panel removal?
Ok i did search and found several articles but couldnt find one that told me how to remove the window crank. I dont want to break it off, but how do i remove it?
Thanks guys!
Old 08-08-2006, 01:26 AM
Default RE: manual window door panel removal?
get a hayes manual from an auto parts store. It will tell you everything you need to know about your car.
There is a clip behind the window handle with the open part towards the roller part of the handle. Turn the handle
so that it is pointed up and then work a cloth back and forth behind it until you dislodge the clip.
Old 08-14-2006, 10:58 PM
you probably already did this but just in case this might be usefull for other people : http://www.club3g.com/forum/showthread.php?t=14857
Thread Thread Starter Forum Replies Last Post
interior door panel removal - 2000 Galant ES fritz General Mitsubishi Chat 5 09-17-2011 02:17 PM
Door Panel Removal -- Please Help the Noob Eclipse Novice 3rd Generation 2 01-06-2008 06:29 PM
inside door panel door removal rocky2024 Mitsubishi Galant 0 10-21-2006 04:17 PM
Door Panel Removal cybergheist Mitsubishi Diamante 1 05-23-2006 01:29 AM
94 Door Panel Removal nachos Mitsubishi Diamante 0 09-13-2005 07:20 PM
Tags
95, club3g, crank, door, eclipse, handle, interior, manual, mirage, mitsubishi, panel, raider, removal, remove, window
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
