03 eclipse stereo wiring trouble
Old 06-12-2007, 10:02 PM
mallet's Avatar
Default 03 eclipse stereo wiring trouble
hey all imnew to the forums. this isnt about my car but my girlfrined bougth a red 2003 eclipse a few months ago. really nice car. we are putting a stereo system in and we hit a few walls in the proicess. one of my questions is how can i wire the center speaker that is above the time and track #. we also bought a Metro wiring harness and dash install kit. do i need both of these? if i have anymore questions ill post them up as i find them out. but if you can answer that question for now it would be great. thanks a lot board!
Tom
Old 06-12-2007, 10:11 PM
mallet's Avatar
Default RE: 03 eclipse stereo wiring trouble
also where are the 6 speakers located. i only count 5 unless the tweeters are counted int he 6
Old 06-13-2007, 08:32 AM
jpmontero98's Avatar
Location: when a man and women fall in love, the man........
metro as in GEO METRO wiring kit and harness? im not sure about that may not work but miricles happen....and for the 6th speaker...you would pretty much copy what they did for wiring the other speakers...+ in + and - in -....here somthin from www.the12volt.com
its 2002 but im sure its similar if not the same
12V|white/red |+ |ignition harness |
| STARTER|black/red |+ |ignition harness |
| IGNITION|dk. green |+ |ignition harness |
| ACCESSORY|blue/red |+ |ignition harness |
| SECOND ACCESSORY|blue/black |+ |ignition harness |
| POWER LOCK|lt. green/black *2 |- |drivers kick panel *1 |
| POWER UNLOCK|orange *2 |- |drivers kick panel *1 |
| LOCK MOTOR|lt. green | |drivers kick panel *1 |
| UNLOCK MOTOR|dk. green/red | |drivers kick panel *1 |
| DISARM DEFEAT|blue/black | |passenger kick panel or *9 |
| PARKING LIGHTS +|grn/wht or pnk/blk | |low in drivers kick |
| HEADLIGHTS|orange |- |headlight relay under hood |
| DOOR TRIGGER|green/yellow |- |fuse box *8 |
| DOME SUPERVISION|green/orange |- |fuse box *3 |
| TRUNK/HATCH PIN|red |- |drivers kick panel *7 |
|TRNK/HTCH RELEASE|green/white |5wi|drivers kick panel *7 |
| FCTRY ALARM ARM|arms with lock | | |
|FCTRY ALRM DISARM|disarms with unlock | | |
| DISARM NO UNLOCK|*6 | | |
| TACHOMETER|*4 | |*4 |
| SPEED SENSE|white/blue | |center console *5 |
| BRAKE WIRE|green/orange |+ |brake pedal switch |
| HORN TRIGGER|lt. green/black |- |steering column |
| WIPERS|blu/org & blu/yel |+ |wiper motor |
| LF WINDOW UP/DN|red/blk - grn/blk |A |drivers window switch |
| RF WINDOW UP/DN|red/wht - green |A |drivers kick panel *1 |
| SUN RF OPN/CLOSE|not recommended | | |
| RADIO 12V|orange/black |+ |radio |
| RADIO SWITCH|white/black |+ |radio |
| RADIO ILLUMINATE|green/white |+ |radio |
| LF SPEAKER|wht/blu - blk/blu | |radio |
| RF SPEAKER|wht/red - blk/red | |radio |
| LR SPEAKER|yel/blu - gry/blu | |radio |
| RR SPEAKER|yel/red - gry/red | |radio |
Notes: NOTE: This vehicle is equipped with an immobilizer. *1 Located in a black 32 pin plug. *2 These are the door key cylinder wires. Meter the wires while turning the key in the drivers door. Unlock requires a double pulse. On vehicles without the factory alarm use purple for lock and lt. green/red for unlock, these are the door lock switch wires. *3 In the plug on the upper right side of the fuse box unde
Old 06-13-2007, 08:44 AM
Dusty Eclipse's Avatar
JP: Metro makes wiring harnesses.
Mallet: If I were you, Id just leave the center channel out of the loop. Especially if youre leaving the stock speakers in tact. All that will happen is it will blow.
Old 06-13-2007, 09:22 AM
ok that clarifys it lol
Old 06-13-2007, 10:21 AM
NubianSithLord's Avatar
for sure leave the center speaker alone i am surprised it is not already blown a huge pos
Old 06-16-2007, 09:00 PM
im goin by this diagram posted in this thread and i just got through installing my radio, subs, and amp but after driving around for a bit the driver's side tail light is out and the drivers front turn signal is out also. so my question is what could be wired wrong?
Old 06-16-2007, 09:19 PM
nevermind i had ended up leaving a fuse out everything works now
beetlenut
01-22-2017 06:11 AM
deadlyrhythm
03-14-2008 12:31 PM
RXtreme8
02-09-2007 12:51 AM
Griffeycom
12-24-2006 08:27 PM
Toohey
06-29-2005 04:20 AM
Quick Reply: 03 eclipse stereo wiring trouble
