Flashers Work/Turn Signals Don't
Old 03-14-2014, 03:58 PM
dunnerstall's Avatar
Default Flashers Work/Turn Signals Don't
1998 Mitsubishi Eclipse. The Haynes manual diagrams indicates there is one flasher unit for both turn signals and flashers. So I am assuming I need to look elsewhere for the cause. Can the flasher unit fail such that I have flashers but no turn signals?
Old 03-14-2014, 09:32 PM
boyette4u's Avatar
ETACS wasn't controlling that just yet, have you checked the hazard switch itself?
Old 03-15-2014, 02:02 PM
No I will ohm-out the Hazard Switch, also. It does appear from the wiring diagram that those contacts can fail in such a way that current is directed to the Hazard Flashers but not the Turn Signal circuit. But am I correct about the flasher unit?
Old 03-19-2014, 07:07 PM
boyette4u's Avatar
The relay/control unit is built into the hazard switch on that car.
Old 03-31-2014, 10:42 AM
I did ohm out the hazard switch and the four contacts tested OK. However the turn signal switch in the combo switch did not test OK. I replaced it and it is working.
Old 08-31-2014, 01:01 PM
Fas2gsx's Avatar
The hazard and turn signal relay are in one unit behind on the right side behind the stereo head unit. It's a black plastic box.
AReed
10-28-2010 12:43 PM
AReed
10-28-2010 12:20 PM
rochford
03-13-2008 05:08 PM
zeanimal2001
1st Generation
04-19-2007 01:28 AM
odecca25
07-13-2005 01:58 PM
Quick Reply: Flashers Work/Turn Signals Don't
