Reverse switch
Old 12-30-2014, 12:18 AM
Boarder67's Avatar
Default Reverse switch
HI all
Thanks for the add, i was in the process of installing a New Audio/Nav unit, with reverse camera into my wifes Mitsubishi Outlander 2008, and i dont know if i touched anything, but the 'R' dissapeared from my dash display, and my reversing lights and radar are now non functioning too, is it the reverse switch i killed or a relay or something? There is also a message on the display to seek a service, and a warning triangle with exclamation mark in it, any help from you Mitsi Gurus would be greatly appreciated.
Carl
Old 01-14-2016, 07:09 AM
outieowner's Avatar
maybe you blew a fuse or something
Old 01-14-2016, 10:25 AM
Guyfromhe's Avatar
Agreed, it's probably a fuse... If you press the info button you should be able to see what the warning is but I would check all the fuses, starting with the ones for the reverse lights.
passionpeng
09-17-2010 12:43 PM
Dumbo45
01-23-2009 09:29 AM
SiCrIcAnRoLLa
08-04-2004 03:41 AM
r0ck182sh0w
11-20-2003 11:21 PM
GrindinGears
06-13-2003 08:01 PM
Quick Reply: Reverse switch
