Timing Tensioner Montero 3.5L help
Can anybody clarify the steps when installing a new tensioner and tensioner pulley. I bought the tool with the pins. What I don't understand is the sequence of tightening goes. If the bolt through the pulley locks the pulley in place while you tension and put the belt on. What happens when you pull the grenade pin from the tensioner. Do I then back of the pulley through bolt?
n.w.m
07-16-2017 12:09 PM
ultramindbrk
01-09-2007 02:20 PM
