3000gt lifters are ticking
Old 10-15-2008, 12:42 PM
crane07's Avatar
Default 3000gt lifters are ticking
mainly when i am stopped at a red light or something of that sort the lifters will start ticking but when i start up and the oil pressure starts to rise the ticking goes away
Old 10-15-2008, 02:15 PM
dsm1990gsx's Avatar
Default RE: 3000gt lifters are ticking
So what do u want to know?
Old 10-16-2008, 06:05 PM
Im having this same issue. My questions are 1. Are these vales adjustable and 2. Where on gods green earth can I find a Haynes or Chiltons manual for my 97? Even their websites don't have the 3000gt listed. Thanks
Old 10-16-2008, 08:26 PM
Double post , but that's ok... i will double reply
1. Change the oil first.. see if that will fix it
2. check the engine oil preasure againest spec
3. replace the lifters.
4. live with the ticking?
ok ok, i added to this post
Old 10-16-2008, 08:40 PM
crane07's Avatar
mainly just is this a problem???
Old 10-17-2008, 07:32 AM
Crane,
valve tappet noise is not a normal thing. The engine is equipped with hydrolic valve lifters that when working properly, remove all valve train clearance and elelveates the ticking noise.
when your hearing the noise, it's not operating as it is designed. Now weather it's a problem or not depends on how much the ticking noise bothers you. it is a sign of wear and or leaking down of oil preasure inside the lifter.
I would at least, check the oil level. for me, the first thing I would do is change the oil. AND if I might add, use the correct viscosity it calls for. Do not thicken the rate. if it calls for 5w-30w then use that. not 10w-40w.
Example, I had a ticking noise on startup in my BMW at 65,000 miles, and used an additive to thicken the oil. It made it worse. I went back to the OEM oil. The ticking has gone away. I currenty have 170,000 miles on the engine and it runs perfectly. If the engine is designed to run a thinner oil, the oil pump flow capasity is greater than in older engines. Running thinner oil is better in the new type engines.
I hope that helps.
BTW; replacing the lifters is probably an expensive repair. Do cheaper things first.
sparkle1
1st Generation
01-17-2009 02:25 AM
crane07
10-16-2008 10:42 AM
Spyder887
08-07-2006 09:14 PM
vientoguy
08-06-2006 06:47 PM
sexybluelady
06-09-2004 05:02 PM
Quick Reply: 3000gt lifters are ticking
