91 3000GT VR4 How expensive is this likely to be?
First, I don't know anything about Mitsubishi. Never owned or drove one.
But, I found a CL listing for a '91 3000GT VR4 with no exterior damage at all and although there's only 2 interior pics, it also looks perfect. Engine is apparently good, but he says 1st gear is out. This model year had the 5 speed.
How much am I looking at for this? Does this use the same transmission as the Dodge Stealth? If so that would probably make it a lot easier, as I am in the US.
Thoughts on 1st gear rebuild vs. buying a manufactured trans? What cars came with the same trans, or one that I could get parts out of?
I assume this car looks like a bit of a headache to own, but it looks like a good headache
They are becoming a sought after collectors car.
3KGT/GTO and the Dodge Stealth are similar..just different exterior styling. The VR4 and the R/T are the same.
You could get the transmission rebuilt and most likely upgraded. Jacks transmission can rebuild it and even make is stronger.
3S AWD Transmission Build Services ? Jacks Transmissions
They are a little hard to work on since the motor bay is cramped but with patience you can. They are definitely cool cars and I owned one I would keep it relatively stock with mild upgrades on the engine.
McAdam
11-09-2010 11:52 AM
jimwoo
02-01-2007 05:26 PM
