Car dies when slowing down to turn please help - Mitsubishi Forum - Mitsubishi Enthusiast Forums
Old 09-14-2008, 02:39 AM
Default Car dies when slowing down to turn please help
i have a 1998 3000gt base with 5 speed manual tranny....no performance upgrades i was having a problem getting it to start but just replaced battery the other day an now it starts an drives fine...the only problem is when i press the clutch in and shift down usually around 2nd gear to make a turn and sometimes wen i come to a stop sign or light the engine jus shuts off....it cranks back up perfectly everytime but its just a hassle wen ur turning and have to strong arm it in..lol...then recrank it....ive been thinking it must be a short or glitch in the wiring on either the clutch or gear shift but i have no clue.....if anyone has any information at all as to what it could be or wat i could try i would greatly appreciate it
Old 09-14-2008, 03:16 PM
Default RE: Car dies when slowing down to turn please help
I had the same problem my car will shut off and was real hard to turn. It happened when I replaced my battery. The terminals were touching the brackets holding down the battery it will stat back up when I will turn it back on, but they wre loose and were just switching side by side. So see if they are away from touching any metal objects. Im not saying that it but that sounds like my situation tha was going on. Well good luck.
Old 09-14-2008, 08:01 PM
i just replaced the terminals and still nothing i dont no wat it could be maybe the idle controlbut its only wen i slow down to turn and its usually about the same speed everytime ive checked everything i can think of
Old 09-14-2008, 09:30 PM
dsm1990gsx's Avatar
Does the car idle fine when coming to a light or stop sign, sounds like an iac to me.
Old 09-16-2008, 01:57 AM
raising your idle problem will fix your problem. it drops too low when you slow down to turn. Common side effect, very simple solution
Let us know
Gus
Old 09-24-2008, 06:09 PM
The same thing happen to my 93 SL. Find your throttle position sensor next to the intake manifold and remove it (two bolts and wiring harness). Take it apart and spray some electrical parts cleaner on the components and let it sit for an hour.
That worked for me and it was much cheaper than replacing it.
Thread Thread Starter Forum Replies Last Post
Need help PLEASE, Car dies when let off gas! cgonser Everything else 0 01-29-2010 07:46 PM
RPM go down and Car turn Off vop Mitsubishi Montero & Montero Sport 11 09-12-2009 02:24 AM
03 galant missing when slowing or stopping speelman Everything else 9 05-14-2008 11:28 AM
When I turn my lights on, idles down? willdue 2nd Generation 5 07-26-2007 10:50 PM
2003 Eclipse slowing down JamesRS 2nd Generation 9 03-31-2004 01:26 PM
Tags
3000gt, battery, car, changed, dies, make, mercury, sable, slow, slowed, slowing, stopping, stops, turn, turning
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
