smoking after long idle - Mitsubishi Forum - Mitsubishi Enthusiast Forums
Old 02-15-2006, 02:34 PM
Default smoking after long idle
When I let my car idle for awhile when I hit the gas it smokes. I suspect a seal in one of the turbos that is leaking. Any other ideas. And if so what does a turbo rebuild cost and where is the best place to have it done? And how do you tell which turbo is doing the leaking?
Old 03-06-2006, 10:26 PM
Default RE: smoking after long idle
i got a 95 non turbo and my car does the same thing. evryone tells me that it is bad valve seals. they arent real expensive but probly cost a lot on labor. check this page out 3sx performance they got a whole set of em for like 80 bucks
Old 03-07-2006, 11:45 AM
Pull your intercooler pipes off (at the Y) and see if they are coated with oil, that will let you know if your turbos are blowing by oil.
It could either be that, your valve stem seals, or your rings are starting to wear. A compression check will rule out rings. More than likely it is the valve stem seals though.
Thread Thread Starter Forum Replies Last Post
1991 Mitsubishi montero 6cyl smoking at idle tatnu72 Mitsubishi Montero & Montero Sport 6 10-26-2011 05:19 AM
cars smoking after new head install,good compression mjboehm 1st Generation 3 02-11-2009 05:23 PM
My 3kgt is smoking during long idle Braunstein82 Mitsubishi 3000GT 9 12-30-2006 11:10 AM
smoking 93 diamante dencomtech Everything else 1 06-26-2004 04:36 AM
Smoking Kills Seth Off Topic 0 04-24-2004 02:19 AM
Tags
3000gt, 97, bad, eclipse, idle, idles, idlining, ilining, long, mitsubishi, seals, smoke, smokes, smoking, stem, valve
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
