Mitsubishi Diamante For the faithful Mitsubishi owner, this car offers high end luxury without high end luxury pricing.
diamante keeps dieing
Old 11-18-2004, 10:30 PM
arcticz28's Avatar
Default diamante keeps dieing
Hi, I have a 1992 diamante and it starts dieing as soon as it warms up. I try starting it again and it starts fine but the dies about 5 seconds later. can anyone help?
Old 12-06-2004, 02:29 PM
Default RE: diamante keeps dieing
I hate to be the messenger, of bad news but you are gonna need to check and/or replace the ECM (brainbox)..my 92 does about the same thing...or it is fuel pump/pressure related
Old 02-25-2005, 09:07 PM
No, it is probably the throtle body is dirty or the IAC (idle air control motor) has failed. The IAC is what controls your idle speed. If the ECU is bad you will get a check engine light. A bad IAC does not have a code.
Old 04-18-2005, 01:10 AM
wicked_outlander's Avatar
first of all, check your tune up....if the problem persist, you may wanna check fuel systems ( hose's, filter, injectors. rails. pressure and pump) then your ignitions. see if you getting enough sparks from your wires.
KaiserEclipse
05-26-2011 05:45 PM
racinrookie88
02-20-2009 08:39 PM
JesterGTO
06-28-2006 10:22 PM
ron Kirk
07-31-2005 01:45 PM
arcticz28
11-18-2004 10:43 PM
Quick Reply: diamante keeps dieing
