Fuel pump problems
Fuel pump problems
I have a 2002 Mitsubishi diamante vr-x, car was running fine till I turned into a parking lot.the car cut off and wouldn't start, motor will turn over, the fuel pump wasn't coming on. Had it pulled to a service station and the guy checked the fuel pump and found it was pumping fuel when the motor is turning but not when the key is in the run position. We thought it might be a bad ignition switch but that wasn't the problem. I can't find a relay location anywhere online but I don't really think it is a relay problem. I have checked all the fuses under the hood and under the dash. I don't know what else it could be. Does anyone have an idea or possibly the same thing happened before?
MNalfa
17
05-09-2019 06:07 AM
agallardo
02-22-2007 03:46 AM
