Mitsubishi Diamante For the faithful Mitsubishi owner, this car offers high end luxury without high end luxury pricing.
messed up the electronics, HELP!!!
Old 05-01-2015, 10:32 AM
Raider's Avatar
Unhappy HELP! i messed up the electronics
today when I went to jumpstart the car, I hooked up the jumper leads backwards and fried the 120 amp fuse under the hood. I replaced that, but now the radio, clock, and the gauge lights aren't working. the gauge fuse under the dash was blown, I replaced that, but still no lights.
what can i do now besides replace the gauges? is there something else that controls all these things that i need to replace now? this is my bosses daughters car, so i need to get it figured out.
Old 05-01-2015, 03:57 PM
Raider's Avatar
the signal lights work, the high beam light works, its just the clock, the radio and the speedo/tach lights that are not working.
should I try replacing the speedometer assembly to see if that fixes it? maybe each component is fried?
could it be the ecu that's fried?
anyone have ANY idea's???
Old 05-07-2015, 09:59 AM
Diam2002's Avatar
Everything is fused for protection, therefore I would not start replacing components without verifying all fuses first. I do note that in the electrical schematics that the Audio, Cruise, Center Display,power antenna, and clock operate off the same fuse link.
Old 06-28-2015, 07:39 PM
Antihero6396's Avatar
There is a little yellowish box in your fuse box under the hood. It has 2 fuses in it. Sometimes it pops up to prevent the fuses from blowing. I had the same problem and pushing that down fixed it.
jmil
05-12-2008 04:26 PM
2nd g eclipse gst
12-11-2007 06:46 PM
xLoveMeXoTenderX
07-26-2007 10:21 AM
max3
06-28-2007 09:29 PM
unreal23
06-24-2005 02:07 PM
Quick Reply: messed up the electronics, HELP!!!
