wont start up
wont start up
Please Help
I was working on my son's Diamante, I just needed to replace a front driver side fender,head light, signal light, and grill. In order to bang out the frame by the signal light, I had to disconnect and removed the battery and windshield water bottle, after successfully removing and replaceing all the mention components, I put the battery back in place and hooked up the lights and water bottle. When I try to start the car, I only get a small click coming out of a relay(looks and sounds like) that is on the driver side just under the glove compartment, All my lights work,the dash board, the radio and when I turn the ignition key the head lights don't even blink. The car was working just fine before.
QUESTION: When I disconnected the battery for a long period, Did the ECU maybe went into a security state, and needs to be reset???
Any help will be greatly appreciated.
RE: wont start up
Start with the simple things. Recheck the area that you worked to ensure you did not accidentally disconnect something. Then take a hammer and lightly rap on the starter. Then check and see if the starter is getting power when you turn the key. I do not believe there is any "security" mode.
RE: wont start up
ORIGINAL: roman067
Please Help
Please Help
RE: wont start up
Hello Roman067,
The ECU (Electronic Control Unit) resets itself after the negative cable bttery cable has been romoved for 20 seconds or more. This will clear any "Trouble Codes" that the ECU may have stored. I'm not sure what year your son's D is, but the ECU on my '92 is on the passenger side and up the right wall. The ECU (unless fried) should not keep the car from starting.
As Winshaw suggests, go back over your work / connections. Check your fuses inside and under the hood while your at it.
Feel fee to go here and ask your questions as well ---> http://www.diamanteowners.com/index....oard&Itemid=30
TG
TG
03LancerT28
05-13-2005 12:20 AM
