Go Back   Mitsubishi Forum - Mitsubishi Enthusiast Forums > Mitsubishi Models > Mitsubishi Endeavor
Sign in using an external account
Register Forgot Password?
Search
Welcome to the Mitsubishi Forum - Mitsubishi Enthusiast Forums.
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 03-16-2011, 01:42 PM
Default 2004 Endeavor
2004 Endeavor, cylinder 3 mifire.
Coil good(swapped from cylinder 5/no change), injector good(swapped from cylinder 5/no change), Plugs replaced(gap not altered), no coolant leakage into cylinder, intake manifold gasket in good shape, valve cover gaskets replaced.
Vehicle misfire at cold start up and occasionally during driving. Mostly at cold startup.
Our next step is to check for a possible sticking valve. Cylinder leakage test tested good. Compression test good.
Car had an alarm/remote start installed on it, causing an ecm fuse to blow, resulting in a tow in.
Has anyone come across any problems with the Endeavor resulting in a misfire in a single cylinder due to ECM issues? Or experieneced a misfire of this caliber caused by mechanical? 125,000 miles on the odo.
Again the misfire occurs mainly at cold startup and ends abrubtly not long after the vehicle warms.
Let me know thanks!
This ad is not displayed to registered members.
Register your free account today and become a member on MitsubishiForum!
Old 03-16-2011, 02:11 PM
Default Continued...
Upon looking into the vehicle again we noticed the #3 coil was faulty(the brand-new Mitsubishi coil replaced recently). A bulletine stated that the coils case expand due to overheating caused by a faulty ground(ground 11). Noticed a capacitor sharing the ground. Most likely put there for interference for that bank. Cleaned ground. This ground controlled the signal side of the ignition to detect of a misfire is occuring. If this ground is loose/faulty/oxidized it could cause the coil(s) to overheat, resulting in a new misfire. Still looking for experience with this problem.
Tags
04, 2004, coil, cylinder, endeavor, endevour, good, identify, misfire, mitsubishi, mitusbishi, problems, remote, replacement, vehicle
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
