2004 Endeavor XLS not accepting programming of new fob
Old 10-24-2015, 02:36 PM
sammyb123's Avatar
Default 2004 Endeavor XLS not accepting programming of new fob
Hello all,
I purchased a 2004 endeavor XLS recently and it had a viper remote for keyless entry but it did not work. I checked the door fuses and they are fine. I looked for a valet button or receiver but found none. I bought a two button fob for an endeavor and went through the steps to program it. place the key in the ignition, jump port 1 and 4 where i plug in the obdII reader and press the hazard lights 6 times until the doors lock and open. The next step is pressing the lock button on the fob 3 times which i did but does not work. Nothing happens when I get to the fob step. I am not sure where to look and what to do. Can anyone give me some ideas on what could be the problem?
Thank you
Old 10-26-2015, 08:39 AM
Guyfromhe's Avatar
Start by putting new batteries in the fob.
Is it a new or used fob? Are you sure it's the right fob for you car?
Old 10-26-2015, 12:21 PM
sammyb123's Avatar
I bought it brand new and came with a new battery. I already ruled out the obvious, I am looking for the next step in troubleshooting the problem, like wiring, finding out where the receiver is etc
Old 10-27-2015, 10:43 AM
Guyfromhe's Avatar
If the car is responding with the lock unlock it sounds like it's able to talk to the controller, etc. A service manual would tell you where the receiver is located...
Is it only a single fob? Sometimes parts just don't work out of the box... If it's more than one it's probably not that....
Old 10-27-2015, 11:38 AM
sammyb123's Avatar
Thank you for the reply. I will have to get a service manual and check it out. I do only have one new fob but the old fob that came with the car did not work either so this leads me to believe it might be something else. I can easily go and have a pro figure it out and do it but where is the fun in that.
If I find out the problem I will post, and if someone has any other suggestions it would be appreciated
Old 10-27-2015, 04:18 PM
Guyfromhe's Avatar
Unfortunately I don't think there's going to be much in the way of diagnosing this it's integrated into the BCM of the car and you probably need a MUT III dealership tool to get any info from it....
Looks like your have an OMRON C system in that car.
"The Receiver Module and antenna are incorporated into the ETACS−ECU on the back side of the fuse block in the driver's side of the dash."
Here is a TSB that might help you: http://mitsupartsworld.com/Diamante%...442a001rev.pdf
Verify the part numbers of the transmitters. The procedure you describe is correct. They do highlight press the button 3 times SLOWLY within 10 seconds, are you pressing then waiting and then pressing again?
Hope that helps.
Also can you post the FCC ID of your 2 remotes?
Ducati996
04-24-2015 02:17 AM
rdublu
11-24-2006 03:18 PM
3000gtskickass
10-15-2006 04:50 PM
caverspencer
05-31-2006 01:53 PM
jaymitsu
12-03-2003 07:33 PM
Quick Reply: 2004 Endeavor XLS not accepting programming of new fob
