Blower Dead / Need Advice ('05 Endeavor)
Old 01-19-2013, 09:47 AM
SkydiverFL's Avatar
Default Blower Dead / Need Advice ('05 Endeavor)
Blower stopped while increasing fan speed. No longer blows on any speed. Heat comes in while vent is open. I'm a noobie, but assuming the blower motor is dead. I have a few questions...
1. Where is the blower motor located on a 2005 Endeavor?
2. Is there a separate fuse or relay just for the motor?
Any advice or tips would be greatly appreciated.
Thanx,
Fred
Old 01-21-2013, 04:19 AM
SkydiverFL's Avatar
Well, the blower motor was easier to find than I thought. How the heck do you remove the plug from this thing? I cannot tell if it's glued in or just hard to remove. Also, the wheel does not turn at all. I've tried measuring the voltage across the leads but it's kinda difficult with it plugged in to the motor. Any advice?
Old 08-09-2013, 02:35 PM
El mitsu's Avatar
Where did you find the blower motor location. Is it under the hood or behind the glove box? Thanks
Old 08-09-2013, 04:25 PM
SkydiverFL's Avatar
It is under the dash beneath the glove box.
Old 09-07-2013, 09:36 AM
thair's Avatar
I just had to replace the resistor after the same thing happened, was changing the settings and no airflow at all. The resistor is behind the glovebox simple fix but be advised that Mitsubishi used a resistor from a Honda civic not Si 2001-2005 so make sure you get the right resistor. Also test your blower motor before just replacing it. As well as trade out the relays to make sure that is not the issue as well.
locke
10-23-2013 06:46 AM
Bradley2007end
08-14-2010 10:19 AM
oscarpup
07-06-2010 10:35 AM
KF97diamonte
05-05-2010 01:38 PM
TitanMax
03-28-2009 03:24 PM
Quick Reply: Blower Dead / Need Advice ('05 Endeavor)
