oil change
oil change
Hi my name is jean I need help changing the engine oil, I wanna now if I can use syntetic oil and what grade is the right one like 5-30 or 10-30 and also how many quarters needs, I have a mitsubishi endeavor 2004 with 28000 miles THANKS FOR YOUR HELP.
RE: oil change
ORIGINAL: Winshawn
Some really good oils.
Castrol 0W30 Full Synthetic (no other weights are good)
Mobil 1 EP 5W30 or 10W30
Red Line 5W30 or 10W30
An awesome, cheap, non-synthetic. Chevron Supreme.
RE: oil change
but if u switch to synthetic get a semi blend first cuz you need to get all the old oil out. put mix in or full synthetic that is a cheap price then drive for 500 miles then drain oil and put fresh full synthetic in
RE: oil change
ORIGINAL: outlancer
RE: oil change
I have a 2004 Endeavor AWD. I just put in Mobil 1 10W-30 extended mileage oil and a Mobil 1 filter, hoping to go with annual oil changes. I've usually gone 6,000 miles between changes. I used Castrol Syntec 5W-50 last oil change, before that was whatever the dealer used (non-synthetic).
I've gone from non-synthetic ("dino") oil to synthetic and back without any flushes on my Chev Lumina APV mini-van and have 172,000 miles in 12 years (currently back to synthetic oil), so an extensive flush is not required (but may be beneficial).
RE: oil change
On my (wife's) 2004 Endeavor I've changed the oil filter at six months on my test of Mobil 1 Extended Life oil. The oil seems to be functioning okay and I've seen worse looking oil on a dipstick. But my wife has put on 10K miles already and the oil is recommended for 15K miles, so might be changing the oil in January. Brrrr.
DClassical
03-30-2005 01:07 PM
