Is steering wheel supposed to lock when the key is removed from the ignition?
Old 07-29-2010, 07:07 PM
Yury's Avatar
Default Is steering wheel supposed to lock when the key is removed from the ignition?
Mine doesn't. I can move the steering wheel side to side and nothing happens, it just moves smoothly.
Old 07-31-2010, 02:06 PM
jgbrules's Avatar
if you move the steering wheel enough with the key out, it will lock. doesnt do it automatically though
Old 07-31-2010, 02:47 PM
Yury's Avatar
I found that the steering wheel has to be upside down to lock, so 'enough' is 180 degrees. I asked the dealer about it and they didn't know what to say at first, but then we went to a new 10 Endeavor they had on the lot and it turned out exactly the same - if the wheel is straight it won't lock at all (well if you have the muscle to turn it 180 degrees without power it will). You'd have to be close to the upside down position when take the key out to be able to lock.
It's a bizarre design.
Mitsu28
11-19-2009 07:12 PM
puwit321
09-05-2008 03:42 PM
Azazel
05-29-2008 02:06 PM
sickend
10-12-2006 12:27 PM
cllamont
4th Generation
02-05-2006 01:55 AM
Quick Reply: Is steering wheel supposed to lock when the key is removed from the ignition?
