Warning Light?
Old 02-07-2008, 12:26 PM
rob985's Avatar
Default Warning Light?
I just bought a used 2007 Endeavor and I don't have a owner's manual. There is a yellow warning light on my dash that I can't identify. It is like a circle with an exclamation point in the middle. It is located on the lower right side of the dashboard gages. Can someone tell me what this light means.
Old 02-08-2008, 12:23 PM
Default RE: Warning Light?
My WAG is that it is the tire pressure indicator. Try pumping up all of your tires to 32psi or so and see if it goes away.
Old 02-09-2008, 10:25 AM
yeah i would say try the tire pressure and that should fix it..Had the same problem and that is what fixed mine.....
[/align]
Old 11-24-2008, 08:20 PM
Well...hello fellow Endevour owners.....
My wife came to me...believe it or not to tell me about a light on her dash.........will wonders never cease.....
Well on to the issue....yes...I too found out that this light is the low tire pressure indicator......but my problem is different...
Living where I do I change the alloy rims for steel rims with winter tires.......now the computer thinks the tires are all low...
Is there a way to turn off the warning....blinking....flashing....strobe light that drives her crazy......and in turn drives me crazy?????
Old 11-24-2008, 09:33 PM
4never's Avatar
I read something somewhere (maybe it was another Mitsubishi forum) but it said that you can possibily remove the fuse for the TPMS and it will turn that warning sign off.
Old 11-28-2014, 09:07 AM
Trilla's Avatar
Most definitely the tire pressure
Old 01-15-2015, 03:54 PM
garyst1981's Avatar
I have the same problem on my 06, at first it appear for a period of time and dissapear, then go back ON and now is always ON... what could it be? does the sensors inside the tires need batteries? is it a lot of work to replace them?
Old 01-19-2015, 08:34 AM
Tyguy's Avatar
I'm also having the intermittent problem with mine. The tire pressures are all fine but the light is on occasionally. I just check the tire pressures when it comes on, then ignore it.
I do need to sell the car soon (family is outgrowing it) so id like it fixed if anyone has any solutions.
chevy047
09-01-2007 08:10 PM
g1bishi
11-08-2006 07:11 AM
waskull
09-06-2006 08:30 PM
Mustang
10-22-2005 03:30 PM
matt02708
05-18-2005 08:32 PM
Quick Reply: Warning Light?
