Warning Light?
Warning Light?
I just bought a used 2007 Endeavor and I don't have a owner's manual. There is a yellow warning light on my dash that I can't identify. It is like a circle with an exclamation point in the middle. It is located on the lower right side of the dashboard gages. Can someone tell me what this light means.
RE: Warning Light?
Well...hello fellow Endevour owners.....
My wife came to me...believe it or not to tell me about a light on her dash.........will wonders never cease.....
Well on to the issue....yes...I too found out that this light is the low tire pressure indicator......but my problem is different...
Living where I do I change the alloy rims for steel rims with winter tires.......now the computer thinks the tires are all low...
Is there a way to turn off the warning....blinking....flashing....strobe light that drives her crazy......and in turn drives me crazy?????
I have the same problem on my 06, at first it appear for a period of time and dissapear, then go back ON and now is always ON... what could it be? does the sensors inside the tires need batteries? is it a lot of work to replace them?
I'm also having the intermittent problem with mine. The tire pressures are all fine but the light is on occasionally. I just check the tire pressures when it comes on, then ignore it.
I do need to sell the car soon (family is outgrowing it) so id like it fixed if anyone has any solutions.
2008, dash, dashboard, endeavor, exclamation, flashing, light, low, mark, meaning, mistubishi, mitsubishi, point, pressure, tire
