Wet Carpet
Old 07-05-2014, 10:19 PM
TechnoGeek's Avatar
Default Wet Carpet
Recently The Driver side Carpet is getting wet.
I think it must be from AC Condensate water.
If it is, where is the drain that would leak only on the Driver side?
Any guidance will be greatly appreciated.
Old 07-12-2014, 11:04 AM
TechnoGeek's Avatar
**Update** Fixed.....
1. 1st Part. I followed TSB-09-55-002 but still leaking when AC used.
2. 2nd Part Put a 12 gauge wire thru the hole and thru the firewall.
3. From under the vehicle I put a 3 foot piece of 5/16 clear tubing threaded on the 12 gauge wire from step 2.
4. Lubricated the 5/16 hose with Electricians Cable lube (Cable snot the guy called it).
5. PN MR450338 (Hose Radiator Condenser $4.56 from Mitsubishi dealer) Thread/Slide it over the Clear 5/16 tube and after making contact with the nipple from the Airbox that protrudes thru the firewall, start twisting it to get it seat over the nipple.
6. Remove 12 gauge wire from the inside, Carefully remove the 5/16 tube from within the MR450338 tube.
7. Use wire tie's to secure it to the Power steering hose.
8. Poured water thru the 5/8 hole from step 1 TSB-9-55-002
9. Verified it was not wetting the carpet of flowing down the inside firewall but only from the hose (MR450338 from under the Vehicle)
10. Plug the the hole from step 1.
Reference TSB-11-55-003 for other details. https://mitsubi****echinfo.com/data/.../520059279.htm
dswa5
02-23-2015 10:23 AM
eduardob
03-12-2009 09:57 AM
aribo
12-26-2008 04:57 PM
dgill
03-16-2004 11:14 AM
Nubian QT
10-09-2003 12:09 PM
Quick Reply: Wet Carpet
