what are those bushings called?
next project - looking for bushings. Again, I am 1000 miles away from the next dealer or autozone etc - gotta order online and hope it will be the right one. Now I understand that it is the rear lower control arm, the circled bushings are bad, I find reference to the outer one (close to the wheel) as being called knuckle bushing.
I look for rear lower control arm bushings, find this one
cheers
(http://www.amazon.com/dp/B00R96RRZY/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=XM65MURPVGX5&coliid=I1371YZFV8MX3N )
but no word about the other one on the inside (the one on the right in the pic), are they the same?cheers
turns out I need ALL bushings - seven of them. now I can find the ones on the wheel side (knuckle bushings?) - one upper and two lower (forward and rear) but still can't find any reference to the inside ones - 4 of them - two on the upper arm and one each on lower arms forward and rearward.
Anybody got part numbers or knows where to get them? are some of them the same or are they all different?
this is a '04 Endeavor LS AWD, rear axle control arm bushings
thanks, appreciate any info!
BrunoBoy650
02-04-2007 11:50 AM
Simss
11-18-2006 10:44 AM
