Go Back   Mitsubishi Forum - Mitsubishi Enthusiast Forums > Mitsubishi Models > Mitsubishi Endeavor
Sign in using an external account
Register Forgot Password?
Search
Welcome to the Mitsubishi Forum - Mitsubishi Enthusiast Forums.
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 01-22-2010, 11:14 AM
Unhappy yet another headlamp problem
both headlamps work as expected in low beams but just one in high beams. switched the bulbs to rule that out and both bulbs are fine. didn't really check on the fuses because i am assuming fuses should work, or not work, for both lamps. are there any known problems with the headlamps, as i have seen other with similar problems? thank you.
UPDATE: now what used to be the only properly-working headlight only works on high beams, so either i have the driver's headlight working in high beams or the passenger's in low beams, but not both, arrrg
This ad is not displayed to registered members.
Register your free account today and become a member on MitsubishiForum!
Tags
beams, brights, endeavor, head, headlights, lamp, low, mitsubishi, outlander, problems, work, working
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
