carbonetic carbon clutch for evo 10
Old Apr 29, 2013 | 07:45 PM
  #21
MMS1970's Avatar
>Sebba
Thank you for all! I will check the ACT 2100 HDSS. what price range is fair price for this item? I am not only chasing price but Just know street price range.
I checked CARBONETIC one $949- with out flywheel and with flywheel $1450- I find some guy supply around $800 and $1100- it might way higher price?
My clutch is still good but I am sure not last long will be gone before summer start.
so shopping around in few weeks ready to go before summer!
thank you
Old Apr 29, 2013 | 08:01 PM
  #22
Should be about half that, between 400 and 500. You're welcome, and good luck!
Get an aftermarket flywheel or have your OEM flywheel resurfaced. Otherwise your clutch will never break in properly. Fidanza makes a great flywheel, so does ACT.
Old May 5, 2013 | 07:07 PM
  #23
Evo advise from sebba, good god what has this web site become...... Evo's are picky with clutched that work well. Hence the extreme swing in prices. a lot of people run ACT products but a lot of people also have gear lock out issues.
Old May 5, 2013 | 08:47 PM
  #24
A lot of people don't know how to adjust or diagnose drag issues properly, that's the cause.
Suck it, Mike
Old May 6, 2013 | 08:56 AM
  #25
A lot of shops don't as well. I suppose that the 85% of Evos that get lock out on ACT products is all on the install then right? Even when people like Buscher and AMS can't get them right most of the time.
Old May 6, 2013 | 11:24 AM
  #26
Shut your ***** mouth Mike.
Old May 6, 2013 | 11:41 AM
  #27
MMS1970's Avatar
Why pople using ACT product has gear lock out? how about any other brands?
Do you know CARBON clutch will be locked out?
Also I know AMS, who can trust for intalation? anyway I need spend $700-800 for imstration in my area so I do not want to missed.
Anyone where is your favorite shop who can trust? If it is CARBONETIC BLADE clutch dealer best. I still very interested in the clutch system.
Thank you
Old May 6, 2013 | 01:17 PM
  #28
You know, if it's a dual disc clutch then it probably comes with it's own flywheel, correct? In that case, it would be the same cost as an ACT plus a replacement flywheel.
If you're worried about gear lockout, then go with the carbon twin disc.
luni
Dec 29, 2006 01:58 PM
david76008
Jul 29, 2006 06:57 PM
eclipseracerx
Apr 28, 2005 01:05 PM
persianevo
Jan 30, 2005 02:42 AM
xtianLANCER04
Nov 23, 2004 09:31 PM
