Mitsubishi Forum Issues Discuss any issues you are having with the forums here.
bleeding brakes on ls200 or warrior
Old 08-06-2009, 05:12 AM
jasondavis10men's Avatar
Default bleeding brakes on ls200 or warrior
Does any one know how come the brakes will not bleed on my warrior.
cheers.
Old 08-21-2009, 02:03 PM
BEAT's Avatar
Because you don't need to bleed them. There is no bleeder anymore on new cars.
Did you open the brake fluid reservoir when you replace your brakes or rotors? if not you have air on your brake hose. You need to calibrate it.
the computer in the car usually do it for you but you need to Calibrate the Calipers.
You only bleed if you have an old car.
msport_2_outlander
01-09-2015 07:30 AM
leejm12
07-27-2013 05:57 PM
yasuji514
03-03-2012 04:44 PM
uscwrollins
01-19-2010 06:29 AM
ictponder
05-17-2006 01:20 AM
Quick Reply: bleeding brakes on ls200 or warrior
