Car cut off on highway!!! Help!!
Old 12-05-2009, 10:42 PM
Thewoodieb's Avatar
Default Car cut off on highway!!! Help!!
2001 mitsubish galant 2.4l loaded. This is my la
Old 12-06-2009, 08:06 AM
dsm1990gsx's Avatar
Need more info? Does the car start back up? Check engine light?
Old 12-07-2009, 08:16 AM
Thewoodieb's Avatar
Default ..
Sorry, it didn't post everything, 2.4L, cut off on highway no restart, has cam movement, has spark, fuel pump turns on, fuel reg isn't ruptured. Not even a burp. I checked around somemore on google and found there was a recall on a ckp sensor because wires were rubbing through and grounding out. I know the ckp works with the cam sensor by notifying #1 cylinder location. Which got me thinking that the injectors aren't firing. Would the engine still has ignition without the ckp in circuit? What do you think? Has anyone else had this problem? Thank you!
Old 12-07-2009, 08:20 AM
Thewoodieb's Avatar
Default ...
To clear up anymore confusion the engine does turn over.
Old 12-07-2009, 11:51 AM
dsm1990gsx's Avatar
Check for spark, fuel and compression. You need all 3 for the car to start.
bronzebogen
13
04-16-2015 07:32 AM
pvtsmyser
09-12-2010 09:15 PM
Genosyne
03-29-2007 09:07 AM
Quick Reply: Car cut off on highway!!! Help!!
