2003 Galant Chronic Alternator Belt Squeal
Old 01-01-2009, 05:43 PM
midgetmurph13's Avatar
Default 2003 Galant Chronic Alternator Belt Squeal
I havea 2003 Mitsubishi Galant es 2.4L. When starting the car, more often in cold weather, the alternator/belt will squeal. Then eventually after idling long enough, the noise will quit. If i start the car with the heat on or headlights, or any other accessory using electricity, the squealing is typically worse. The first thing i did was tighten the belts, which did not work. The next thing i did was replace all belts and idler pulley for air conditioner. In a short time the squealing was back. Then i replaced the alternator, with yet another alternator belt, which was a gates belt. Upon doing this, there was little or no belt noise but then the horrible sqeaking came back. So then i replaced the battery which had no effect at all. Then i replaced the alternator again, and the belt still squeals when you start the engine with any accessories on. I have tried everything i can think of and i have never had trouble fixing this problem before on any of the hundreds of cars i have worked on. Any help or advice would be appreciated.
Old 01-01-2009, 07:02 PM
Manybrews's Avatar
Default RE: 2003 Galant Chronic Alternator Belt Squeal
probably a failing crankshaft pulley. Chances are its seperating.
either that, or you dont actually have the belt tight enough.
Old 01-19-2009, 01:37 AM
Did you solve the mystery squeal, and if you did...what caused it?
I have a similar problem and have tried almost everything
Old 07-18-2011, 02:55 PM
brians90's Avatar
Exclamation
I have the same question as the guy befor me. I just bought a 2003 galant with the exact same problem. Ill start it, It sounds fine. I turn the air on and it squeels like a #$%^. Then ill turn the air back off and its fine again.
After its drivein for awhile and drivein lightly the sound stops.
Ive got 1 new belt and one old belt.
Timeing belt and serpintine.
Not sure which is which.
So in my opinion, i think its the belt that turns the ac compressor.
After i replace that ill repost and tell yall if it fixed it.
Old 04-16-2021, 01:41 PM
the kid's Avatar
Default has anyone solved this crap
mine gets worse and worse every time on a cold start and it happens sometimes when you accelerate
Nrengle
04-11-2015 11:16 AM
lovinmrv
12-31-2011 12:33 PM
PCB
11-19-2010 01:52 AM
ibbster
09-25-2007 09:00 AM
bedjemp
05-19-2005 02:02 PM
Quick Reply: 2003 Galant Chronic Alternator Belt Squeal
