Faulty cig lighter & Accessory Outlooks
Old 07-15-2005, 08:11 PM
pauljdodson's Avatar
Default Faulty cig lighter & Accessory Outlooks
Faulty cig lighter & Accessory outlets. Both are not working! Checked the fuse and it is ok. Now what???? Any help would be appreciated for my 1999 Mitsubishi Galant. Both outlets are on the center panel not the ashtray.
Thanks
Old 08-07-2005, 02:17 PM
Default RE: Faulty cig lighter & Accessory Outlooks
perhaps the wires came loose that go to the back of the plugs?
first pop off the trim around the shifter and that will give access to pull out the piece that has the ashtray and the plugs
to do so first remove the ashtray and then lift from the bottom of that area, you will even see a little handle looking like thing to get a grip on
7-UP BILL
03-11-2012 11:00 AM
klas
10-11-2007 07:36 AM
98eclpsrider
08-29-2006 01:04 PM
TDAWG
14
05-16-2006 12:01 AM
Flipz
01-06-2005 05:11 AM
Quick Reply: Faulty cig lighter & Accessory Outlooks
