Key Replacement Procedure
Hi All,
I recently purchased a use '03 Galant that came with only 1 key. Because of the microchip, the dealer wants over $100 to make a 2nd key.
I found a thread on this site that identified a source for a replacement key. My question to you is: with only 1 key, can I authorize this replacement key? The Owners Manual very specifically says you must have two. I just wondered if perhaps I could use the same key 2x while following their procedure.
Thanks in advance.
Thanks in advance.
dude, suck it up and go to the dealer and let them hook you up with a new key and programming. gonna run you Around 150.00. all these websites telling you to do this and that and you get nowhere. there is 2 ways to program that key. one without using the mitsubishi scan tool and one with. still have to have the pass code either way. its takes about 5 minutes to program that key. another 15 to twenty minutes for the parts department to cut the key. so make an appointment AND SAVE YOURSELF A BIG HASSLE.
mrvivona
06-12-2011 12:08 PM
2009, codes, diamante, eclipse, endeavor, galant, key, keys, lancer, make, mistubishi, mitsubishi, online, replace, replacement
