P0441 in 2001 mitsubishin galant automatic 4 cyl.
We have mitsubishi galant 2001 automatic 4 cyl. and it has p0441 code and it says ...incorrect purge flow...
but there are too many possibilities..what should we start with or what is the most common issue causing this error code?
Evaporative Emission Control System Incorrect Purge Flow
...I found that evap purge control valve or evap vent control valve could be culprit ..mainly vent control valve..
where are these two valve located in 2001 galant ? ...I read evap vent control valve/solenoid located on canister...and canister is on gas tank?
