PO431-Warm Up Catalyst Efficiency Below Threshold (Bank 2)
I know that this means that the catalytic converter is no longer functioning properly; An oxygen sensor is not reading (functioning) properly; or there is an exhaust leak; but what is the likelihood of each of these occurring? Has anyone been here before, and if so, what did you do to remedy the issue? I'm not looking forward to shucking out $400 for a cat converter if it's possibly something simpler. Thanks for your help.
There's a way to do that with a gallon of
Thinner pour it in your gas tank, drive your
car in the Freeway high speeds for about a
Hour.. The thinner will remove the carbon
inside the catalytic converter.
A lot of the times the converters plug up
that's when P0431 comes out.
Are you talking about regular paint thinner, like acetone? Have you done this yourself? If it was my car, i'd say fuŠk it and try it, but its my wife's daily driver and baby hauler. I want to make sure this doesn't solve one problem at the cost of causing others. Thanks!
dukeassa
05-06-2011 06:10 PM
