reving idle, throttle while driving
Old 11-29-2004, 02:41 AM
bdunn's Avatar
Default reving idle, throttle while driving
The idle revs up starting at 1500 and quickly going to 2000rpm over and over etc while stopped. It continues to push the throttle (bet 1500 and 2000rpm) while driving (and stopping). I have an automatic, and I assume the problem is electrical etc. What should I check first?
1995 Galant
Old 12-01-2004, 03:38 PM
Default RE: reving idle, throttle while driving
First the Airflow sensor. Located right after the air filter unit. Next i would check the idle air controller. That's kinda hard but there's a write up on it in the Vfaqs. (www.vfaqs.com) If thoses all turn out to be ok, then things might be a little more serious. Things such as engine timing and fuel delivery might be the problem. Hopefully though, those are two very common parts that can go bad over time, so the probem might not be to costly.
mko
12-10-2009 07:35 PM
Electech1
11-03-2006 10:29 PM
vr4luver
02-24-2006 01:19 AM
1997gsteclipse
12-08-2005 03:10 PM
ron Kirk
07-31-2005 01:45 PM
Quick Reply: reving idle, throttle while driving
