From where do you drain the transmission fluid in a 2001 Galant v6??? - Mitsubishi Forum - Mitsubishi Enthusiast Forums
LinkBack Thread Tools Search this Thread
Old 03-24-2013, 07:22 PM
Question From where do you drain the transmission fluid in a 2001 Galant v6???
It's a 2001 3.0 v6. It has the incorrect type of ATF in it now and is shifting horribly. So I got the correct SP 2/3.
Where do you drain it from?? most cars there is a distinct tranmsission oil pan and a drain plug just like regular oil..
Thread Thread Starter Forum Replies Last Post
what kind of transmission fluid to use in my 2008 galant IanHancock907 Mitsubishi Galant 0 01-07-2012 12:54 AM
97 mirage transmission drain plug location? ShingenTokugawa Mitsubishi Mirage 2 03-09-2009 03:27 AM
Outlander Transmission Drain Plug? gsnoddy Everything else 1 08-12-2007 01:06 PM
95 Galant Transmission Fluid and Suspension Recall wsia5012 Mitsubishi Galant 1 02-06-2006 02:30 AM
HELP - Drain tube location on 2001 Galant monkey714 Mitsubishi Galant 0 08-04-2004 12:31 AM
Tags
2001, atf, drain, fluid, galant, located, mitsubishi, model, number, oil, plug, properly, transmission, type, v6
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
