Defective idle control servo... Improvise!
Old 02-11-2014, 01:58 AM
tek349's Avatar
Hello po, same din po problema ko. Myron po ba kau diagram kung paano mag bypass ng servo motor.
Salamat po.
Old 03-29-2014, 12:53 AM
trooper_art's Avatar
guys, i have the same problem with my 2000 lancer MX, idle up problem when the engine is cold and aircondition when turn on. as per mechanic i have to replace the servo unit including servo sensor.
anyone here from QC service servo bypass?
Old 07-25-2015, 08:05 AM
joemluc's Avatar
Default saan po kayo nagpa ayos?
Originally Posted by chis51hd
Hello everyone. I own a 1994 Lancer GLi (4G15 engine) with 87,000km. on it. After purchasing the car I noticed that the engine wouldn't idle up when the airconditioning was turned on. I took it to my usual mechanic, but they couldn't find the problem. So we went to another mechanic who specializes in fuel injected/electronically controlled engines. He immediately found that the idle control servo was defective. He also said that he already encountered others with the similar problem (apparently this is inherent in older Lancer models), and upon replacement of the servo, the problem usually comes back. So we came up with a "solution". We just left the servo as is, and replaced it with a mechanical system. First they installed an actuator--pretty common device, and attached the terminals to the aircon compressor, so it would activate when the aircon is turned on. Then tapped an air hose (not sure which one) to supply airflow to the actuator. Then attached a sort of vacuum hook to the throttle body. When the actuator is activated by the aircon, it also activates the vacuum hook and pulls the idle "thingy" (the one where the accelerator cable is attached to), and brings the rpm up to 1,000. Problem solved.
I just would like to know if anyone else has tried this, and if there would be any ill-effects to this procedure? The car runs fine, and engine idle is sufficient when the airconditioning is turned on. I can see that it's a pretty simple fix, and I only spent about $20 (parts and labor).
Hope to hear your opinions on this. Pictures below:
[IMG]local://upfiles/12443/7165C31FBF7B4034A955686741082842.jpg[/IMG]
[IMG]local://upfiles/12443/B679E51BC8224963B2A9317A7DD22528.jpg[/IMG]
I have d exact same prob mo. Saan po ba kayo sir nagpa ayos ng sasakyan nyo. I being charge by my mechanic P 3k. Ive already spent much just to get this car into excelent running conditon? I really need help. Here is my contact number po, 09164146912
Old 09-15-2015, 09:22 PM
Remliw Nagisaram Atelsi's Avatar
Default defective idle control servo
sir may i ask where you in dasma so that i can go to your shop. i want you to fixed my auto about idle control problem. can you give me your updated phone number cause the number that post to this page is not in service. tnx and hoping for your positive response.
Old 12-15-2015, 05:30 PM
alexd1204's Avatar
Mga sir,
Did you get any reply from sir levi11 kung saan siya sa dasma cavite? Kelangan ko ring magpaayos ng servo ng lancer ko. Thanks
Old 01-05-2016, 08:36 PM
korner's Avatar
Default Servo fix
Does anybody know whether this problem has been fixed on the factory assembly line?
Old 01-23-2016, 04:16 AM
aures_88's Avatar
need ko po nag bypass ng servo for my lancer GLI '94 .. pm me po around Dasma, thanks
Old 03-08-2016, 12:51 AM
Vassili zaitsef's Avatar
My car same problem,96 gli lancer, may i request toyota idle up installation procedure, tnx
Old 03-08-2016, 12:54 AM
Ok po ba ang toyota idle up para po sa lancer gli 96? How to install? Tnx
Old 06-06-2016, 01:55 AM
Haredio1981's Avatar
Default Servo bypass
Originally Posted by Danilo Alviola
i also bypassed my defective servo about 3 days ago on my mitsubishi lancer 1995 model and i paid it 2200 pesos. im still observing its operation.
Hi sir Danilo. Just wanted to know where you had your servo bypassed? I happen to be in Quezon City and I'm not really familiar of any service center or talyer who can do this.
Hoping for your speedy response.
Thanks.
Quick Reply: Defective idle control servo... Improvise!
