Wiring Tachometer 4g15 / 1.5 injection 1992
Old 06-05-2012, 12:21 PM
Mitsufani's Avatar
Question Wiring Tachometer 4g15 / 1.5 injection 1992
Hello !
I realy need help with tachometer wiring, Actually only with Signal wire.
Where should i connect that Green (signal) wire from Tachometer ( aftermarket )
Cause in my car does not have coil where to connect it. So do i need to find some wire from ECU or what
ALL HELP WELCOME ! And thank you ! =)
Old 06-08-2012, 07:02 PM
armeddoc's Avatar
I put a new cluster with tachometer in my 00 Mirage, but i'm not sure about yours. On mine there was a little blue connector in the engine bay on the passenger side where the wiring came out the cabin. That is the tach signal. But i actually bypassed it and tapped into the wire on the ECU. Although i know its different on yours.
Old 06-10-2012, 06:58 AM
Rleo6965's Avatar
How about trace the tach signal wire from the original tachometer.
Bugly
08-31-2011 09:20 PM
mrc1991
10-27-2010 10:16 AM
xybb
12-05-2008 07:27 PM
m3kgt_99
03-07-2006 01:11 AM
unknown_owner
11-23-2005 02:16 PM
Quick Reply: Wiring Tachometer 4g15 / 1.5 injection 1992
