95 Mirage
95 Mirage
I just purchased a 95 Mirage LS Coupe yesterday that drove fine when I test drove it but after I had it transported home it wont start. It has gas, you can hear the engine turn but its like it cant catch a spark. What should I be looking for as far as a fix?
Needs a major tune up. must be 4G1 engine.
replace everything.
buy a new engine if you can afford.
http://www.google.com/products?hl=en...title&resnum=4
replace everything.
Well after a long day I figured out my mistake and got the distributor in and adjusted the idle speed. When I took it out on the road for a test drive it seemed to hesitate sometimes at take off...especially when the AC was on. Maybe I'm just used to driving the Tahoe everyday and not used to driving a 4 cylinder. I just want to try my best to make sure I dont get stranded on the road.
Ok well today I took the car to a shop to let them check everything out since the distributor started the car last weekend. When I drove it to the shop it seemed to hesitate a little during driving. They told me that it has a misfire on cylinder #2 and suggested I change the plug wires and plugs first and then if it didnt work to check the injector or #2. As I was driving the car home it had very little power when driving and when I got 2 miles from the house it started to smoke so I pulled over. I looked under the hood and saw some smoke coming from underneath and when I looked underneath my catylitic converter was bright red. I had it towed home and will look at it tomorrow. Could a misfire cause the car to act this way?
Powertech
03-29-2006 01:10 AM
95, air, cap, conditioning, distributor, gap, hesitates, mirage, mitsubishi, off, plug, remove, replace, rotor, spark
