High and low beams are on at the same time
2000 Mirage DE Coupe 1.5l 5 speed
I just bought this car about a week ago. My problem is that when i turn on the headlights the high and low beams come on. Flicking the dimmer switch doesnt always turn the high beams off. When I try to turn the high beams off the high beam indicator light doesnt go off but it does get a slight bit dimmer.
This is an intermittent problem so i dont think it could be a relay issue.
I checked all the fuses and cleaned/re-lubed the dimmer switch.
Any suggestions?
Any suggestions?
