TP Sensor
Old 07-13-2008, 08:55 PM
rschemera's Avatar
Default TP Sensor
I have a 2000 mirage which kept dying at idle. I had my computer read and it came back with the code for the throttle position sensor. I since replaced it and now the car is bucking at low RPM's. Does any one have any suggestions to what the problem may be? Does the sensor have to be adjusted some how?
Old 07-14-2008, 07:51 PM
dsm1990gsx's Avatar
Default RE: TP Sensor
It shouldn't have to be adjusted, is the check engine light still on?
Old 07-14-2008, 11:06 PM
silvercoupe97's Avatar
Moved to so that you could get more responses.
Old 07-15-2008, 07:15 AM
rschemera's Avatar
The engine light is still on. Do I need to reset it? How do I reset it? Disconnect the battery for about 10 min?
Old 07-16-2008, 07:19 PM
dsm1990gsx's Avatar
Disconnect the battery and drive it around and see if it is any better. If not check it again for codes.
puwit321
09-30-2014 12:10 PM
Rlopez89
07-16-2013 05:21 PM
batman47
12-04-2011 04:21 PM
sickend
09-12-2006 06:25 AM
5Tizzle
08-14-2006 12:07 AM
Quick Reply: TP Sensor
