01 Montero XLS "PO173" code
Old 11-08-2012, 07:03 PM
grannys65's Avatar
Default 01 Montero XLS "PO173" code
I noticed about 2 months ago that my montero was not getting the MPG its supposto be getting, yesterday my wife altered me that the service engine light came on. Today i took it to a friend who has a scan tool. He hooked it up and this code popped up.
PO173: Fuel Trim Malfunction (Bank 2)
My buddy said most likely vacuum leak. When i got home i checked all the vacuum hoses, i sprayed carb cleaner all around the intake manifold to try and see if i could get an idle difference, no luck.
I do notice when its in idle, it has a slight rough idle, it feels like a miss fire but its not. Whats first to check? MAF sensor? how would i go about checking that out? also i did replace the bank 2 (one before the CatConverter) O2 sensor about 4 years ago, the original one went out. My Montero has 121000 miles on it.
Suggestions please, hope others have come across this engine code.
Old 01-29-2016, 07:17 AM
2001Mitch3.5XS's Avatar
Hi Granny, It sounds to me that you have a valve hanging problem.. How is the timing belt .. I had to change mine at 120,000 just food for thought...
Old 01-29-2016, 05:49 PM
Connect the scan tool and check for misfires. Hopefully you can ID the cylinder that is giving you trouble. Can have multiple reasons for a misfire, but that can explain the fuel trim code.
You can also check the O2 functionality while connected.
jsevinsk
08-14-2022 10:36 AM
01monterob
05-19-2015 08:16 PM
Trick
08-04-2013 10:30 AM
treasguy
01-28-2010 07:15 PM
Quick Reply: 01 Montero XLS "PO173" code
