2001 Montero, Limited, overheats
Old 07-28-2014, 12:38 AM
Yehawg's Avatar
Question 2001 Montero, Limited, overheats
We have tried many things to get the overheating to stop, but nothing has worked. We have had the water pump changed, flushed the radiator/engine, replaced the thermostat, twice, replaced the heat sensor, checked fans, hoses, and made sure no air was trapped by filling with bleeder bolts out. Overheats going up a slight grade after 5 to 7 miles & have to turn on the heater to keep from getting to hot until I can go in a different direction that is more level. Took bottom hose off & radiator emptied quickly so I don't feel it is the radiator. What am I missing.
Old 07-28-2014, 10:00 AM
Haynes1701's Avatar
This may seem like a stupid question, but is your Montero actually overheating or are you just getting a "hot" reading on your temp guage in the instrument cluster? The temp guage has a known fault in the circuit board behind it that starts to play up on almost every model year of this Montero. Truck reads "hot" after a few minutes, without actually overheating. Mine started doing it this spring. I plan on re-soldering the circuit when I get time.
Old 07-28-2014, 10:00 PM
Second Haynes on this one. I had the same issue a while back - the temp gauge shoots all the way to high while doing barely any driving. However, the engine was actually not overheating. It is not a pleasant feeling watching that gauge for a minute or two until it returns back to normal range. Haven't done it lately, i guess things rattled around enough and re-connected back together
On the off chance that your Monty is actually overheating - the book suggest checking thermostat (sounds like you've done that), drive belt slippage (I think this would be timing belt that drives water pump and serpentine belt that drives cooling fan), testing temperature sensors. If all those are OK, you can remove the radiator and flush it out with some cleaning/descaling material. Also, is your radiator fins clear or all jammed up with debris and all bent up? That may result in heat not transferring efficiently.
Old 07-30-2014, 03:07 PM
Mr. Z.'s Avatar
A new radiator cap is not a bad idea (cheap insurance).
In addition, the fans on the Gen III are clutch driven.
The viscosity of the fluid in the clutch can degrade over time.
You can recharge the fluid yourself if it has lost viscosity.
Just a couple more things to try if needed.
HTH
Old 08-05-2014, 02:48 PM
I.O.N.Doyle's Avatar
I'll third the faulty gauge but it still needs to be addressed. I have a bad gauge on my 2001 but got lazy and didn't listen to the wife when she said it seemed like it really WAS getting hot. As part of another job on it (lifters/valve seals) I was replacing the timing belt and water pump too and found that the old belt had loosened and was not fully spinning the pump. Lukily I think I caught it in time but if I had not been doing the other work overheating was probably in the future.
Old 09-17-2014, 09:44 AM
kitsr20gtir's Avatar
I had the same problem. I replaced temperature sensors, radiator and cap, fans, water pump and I still had the problem. I've been trying to fix for a year now and finally found a fix. I replace the cluster module. part # MR532787
Old 09-26-2014, 01:52 PM
Slotho's Avatar
Nice troubleshooting, Great post. Well done.
JimNAZ
05-19-2014 05:20 PM
Dana Adude
08-12-2012 02:58 AM
imoapie
07-31-2009 07:20 PM
Furby032306
03-21-2008 05:37 PM
mdctalon
08-02-2004 11:20 PM
Quick Reply: 2001 Montero, Limited, overheats
