2001 Montero Sport P0401 Code Help
Old 04-17-2012, 05:11 PM
HWGoodson's Avatar
Default 2001 Montero Sport P0401 Code Help
I keep getting the P0401 code on my 2001 3.0l Montero Sport. Vehicle starts, idles, & runs great. I checked the EGR + ports all clean, EGR appears to be working. Retrieved following Freeze Frame (I don't know how to interpret)
Fuel Sys 1 OL-Drive
Fuel Sys 2 OL-Drive
Calc Load (%) 13.73
ECT(F) 203
STFT B1(%) 0.00
LTFT B1(%) 3.13
STFT B2(%) 0.00
LTFT B2(%) 5.47
Eng RPM 1503
Veh Speed(mph) 49
Any suggestions on narrowing down the culprit?
Old 05-23-2017, 07:39 PM
yatin_ash's Avatar
What was the solution to this problem?
Old 04-14-2020, 05:28 PM
Chaphall's Avatar
Default Same Issue
Fuel Sys 1 OL-Drive
Fuel Sys 2 OL-Drive
Calc Load (%) 13.73
ECT(F) 203
STFT B1(%) 0.00
LTFT B1(%) 3.13
STFT B2(%) 0.00
LTFT B2(%) 5.47
Eng RPM 1503
Veh Speed(mph) 49
I have
Old 04-14-2020, 05:30 PM
Chaphall's Avatar
I have the same problem... ERG valve & Solenoid replaced
Old 04-14-2020, 07:36 PM
Most likely bad EGR solenoid. You can check to make sure EGR valve is working by running engine at idle, and pulling vacuum with the hand pump on the ERG valve vacuum port. If engine sputters and dies - EGR valve is working properly.
Old 04-14-2020, 07:44 PM
Chaphall's Avatar
Yes and yes... all of that has been done...still showing the code
Old 04-14-2020, 10:22 PM
Did you replace EGR solenoid with Mitsubishi OEM, or with an aftermarket? I found that aftermarket ones work at first, but eventually throw the code again. It had something to do with the duty cycle of the solenoid. It is not just a simple ON/OFF state. These solenoid cycles hundreds of times per minute to regulate EGR amount admitted to the engine. Aftermarket senoids somehow fail with that load.
cbarn96
05-06-2013 10:06 PM
shark07735
19
02-10-2013 07:51 PM
grim0reaper0
09-06-2007 05:00 PM
jcfoshe
07-19-2007 09:03 AM
Bnchs
07-07-2006 03:29 AM
Quick Reply: 2001 Montero Sport P0401 Code Help
