2002 Limited Upper Glove box locked
Old 09-07-2014, 08:31 PM
maco35's Avatar
Very nice.
Old 11-21-2014, 09:17 AM
rubs65's Avatar
Hi All I'm from blighty and I have the Japanese import pajero with the same problem , but I don't have the key entry on the bottom glove as pointed out so how would I go about opening both of mine as they are both locked , the UK sight is helpful but I haven't found anything on there to show how to help ..
Old 03-08-2015, 12:41 AM
redturboeclipse's Avatar
I forgot to point out when I first mentioned this, that yea there are 2 keys. One key won't open the glove box lock. So if you don't happen to have all the keys as if you purchased the car new, just hope the key you have is the one that also opens the glove box.
If not, the trick will still work, but you will have to do as one person did and pick the lock or have someone pick it.
Old 03-08-2015, 11:26 PM
PalmSprings's Avatar
Default 2 glove boxes?
I never knew about the montero sport having 2 boxes. Must have been an option.
Originally Posted by alsaaron
Dude... thanks so much for these instructions! Just got a 2003 Montero Limited and started having trouble with the top glove box. Drilled a hole and, boom, there was the key hole. Key worked fine... switched the two locks as you suggested and it looks fine to me. Probably drilled too hard because I went into the lock a bit, but no big deal. Here are some pictures.
Old 12-27-2015, 10:50 PM
Low Class's Avatar
Just had the same problem with my upper glove box on my recently acquired '03. Had me a little worried I would tear up the dash to get it open. Thanks for this thread!!
Old 02-04-2016, 05:10 PM
I only have one glovebox. Were two an option? never seen 2 gloveboxes in anything......that i recall.
Old 02-04-2016, 06:05 PM
maco35's Avatar
What year is your truck? mine also has 2 gloveboxes.
Old 02-06-2016, 09:43 PM
Default were tandem gloveboxes an option in montero sport
mine are both 01s...oly have one. I mean how many gloves are you supposed to keep in your vehicle anyway?
Old 02-07-2016, 11:10 AM
maco35's Avatar
I didn't see this post before, the full size Montero is the one with 2 gloveboxes.
Vadimus
06-28-2012 06:59 PM
anywidget
12-02-2011 03:13 AM
Punisher
05-19-2006 04:40 PM
dsmturbo
02-09-2006 03:13 AM
Quick Reply: 2002 Limited Upper Glove box locked
