2003 Montero 3.8 liter: where is camshaft position sensor ???
Old 03-08-2016, 05:47 PM
wilde's Avatar
Default 2003 Montero 3.8 liter: where is camshaft position sensor ???
2003 year Montero 3.8 liter will crank but not start. It's the camshaft position sensor. I've checked other stuff and my RPM isn't moving when starting either. Where is the camshaft sensor? Can't find the location anywhere online. This is a 3.8 liter version, 2003 year.
Old 03-09-2016, 05:32 AM
larry4406's Avatar
I have a manual for the 3.8L 6G75 engines. It shows the sensor to be on the rear of the drivers cylinder head where the cam thrust plate and o-ring is. It is Item 4.
On my 3.5L 6G74 the cam position sensor is located at the front of the drivers cylinder head and there is a notched pickup wheel on the back side of the pulley.
Hope this helps.
Attached Thumbnails 2003 Montero 3.8 liter: where is camshaft position sensor ???-3.8l-6g75-cam-position-sensor-rear-drivers-head.jpg   2003 Montero 3.8 liter: where is camshaft position sensor ???-3.5l-6g74-cam-position-sensor-front-drivers-cylinder-head.jpg
Old 03-10-2016, 07:15 AM
wilde's Avatar
Yes that does help. It's on the drivers side rear of the motor, in a nice easy spot to access, like all the other timing parts. Lol. Thanks much!
Sephiroth
02-25-2018 07:46 AM
Sephiroth
06-04-2006 03:03 PM
Rogo
11-23-2005 03:12 PM
Jeffb1
10-01-2005 04:51 PM
michael49
05-16-2005 10:30 PM
Quick Reply: 2003 Montero 3.8 liter: where is camshaft position sensor ???
