2003 Montero Limited high speed miss firing & cold morning knock
Old 09-29-2015, 11:06 PM
wilde's Avatar
Default Fix report
The fix was this:
Butterfly valves in the manifold had tiny screws that had come out over time. Engine ingested one but seems OK. Another 2 were about to go. All cylinder pressures good. I removed the entire butterfly assembly that seems to help with idle and cold starts. Only problem this causes is infrequent rough idle sometimes... no ryhme or reason why I've been able to find though.
This is likely why so many of these 3.8 liters are blown up before their use is full. Ingesting screws into cylinders is not ideal! Very dumb design indeed!
Old 09-29-2015, 11:33 PM
Glad you were able to catch that before it became a bigger problem.
KarenV6
31
03-27-2019 01:24 PM
95Eclipse GST
10-13-2014 10:18 AM
Randys
08-22-2011 12:02 AM
Eclipseprince
01-29-2010 01:15 PM
burn0ut350
08-07-2007 12:38 AM
Quick Reply: 2003 Montero Limited high speed miss firing & cold morning knock
