2004 Montero Seats
2004 Montero Seats
Hello,
I just purchased a 2004 Montero Limited. I did not get the owners manual with it and am trying to figure out the second row seats. Do both of the seats tilt forward or is it just the small one on the drivers side?
Thank you...
Thank you...
Both parts of the split seat should fold forward. It is possible that the cables and mechanisms inside the seat are gummed up and not releasing properly even if you are pulling up on the little lever on the back of the seat. You can fix it by climbing in behind the seats, removing the back cover of the back seats (just a few philips screws) and cleaning/lubricating the mechanisms with some WD-40 and then applying some lithium grease.
Work the mechanism few times to make sure to clear all the gunk out and you'll be back in business.
BroSarge
09-24-2014 06:42 AM
jacobhayhurst
06-29-2012 04:43 PM
iajet
03-01-2012 01:51 PM
