4x4 blinking lights-repaired!
Old 02-08-2009, 06:14 PM
rjr325's Avatar
Default 4x4 blinking lights-repaired!
2001 montrero limited with 4x4 blinking front axle(green) and interlolck light(orange) blinkig. iguess this is a common problem. after reading many posts i desided to put the truck up on ramps and go under and grease up the actuator that engauges and disengauges the front axle. i noticed that one of the vacuum lines that connects to the actuator had a
small hole in the hose, so i cut off the section with the hole and reconnected, road tested, problem solved. hope this can help anyone else.
ole
19
06-10-2015 10:47 AM
shownuff80
05-12-2014 06:21 PM
bigdaddymetal
12-06-2008 05:39 PM
ultramindbrk
07-29-2007 03:07 PM
Moualogic
09-26-2005 10:04 AM
Quick Reply: 4x4 blinking lights-repaired!
